Go Back   SUPERNISSANS.NET Nissan Owners Community > TECHNICAL/RACING FORUM > Suspension, Brakes, Wheels and Tires
Old 11-28-2008, 07:25 PM
lab_rat is on a distinguished road
Default TPMS & wheel size questions
Hello forum,
I am trying to narrow down the wheel choices,but in order to do that I have some questions:
2008 SE-R wheels: are they compatible with the TPMS?
NISMO Maxima wheels: with the Eibach Pro-kit and a full load (5 people plus luggage) will the wheels/tires sag enough to hit the fenders in the rear?
With the Eibach Pro-kit, which set of the above wheels will be better for everyday drivability (aesthetics aside, purely from a driving dynamic standpoint).
Thanks in advance,
Steve
a.k.a. 'lab_rat'
2008 Altima 2.5s
Old 11-28-2008, 07:39 PM
ManicSquirrel's Avatar
Squirrel Czar
ManicSquirrel will become famous soon enoughManicSquirrel will become famous soon enough
i don't know for sure....but i saw a 3.5 SE sedan on the highway yesterday with 5 people, and i assume luggage in the trunk and the back was sagging real bad with the stock suspension, the wheels were bowed out pretty bad. i've never had more than just 4 people in my car, and the back hung a little, but no rub. also the TPMS will work on any wheels you put the sensors on
2007 3.5SL (with tech package) Radiant Silver : Nismo cat-back : Injen WAI : 35% tint : 19" x 8.5" Enkei RP03's/Bridgestone RE050A 245/40-19 : Eibach Pro-Kit Springs: PIAA plasma ion yellow fogs : stealth turn signal bulbs
Old 11-28-2008, 07:49 PM
Thanks for the quick reply.
The only reason I say 5 people with luggage is using the most 'extreme' example, so that on that rare occasion that it happens, I won't damage my car/wheels.
Your wheels are 8.5 wide; do you know your offset? They look great.
Thanks,
Steve
Old 11-28-2008, 07:55 PM
Squirrel Czar
they are 42 mm offset, i have the stock 16's back on now, they they actually rub if i have the steering wheel at full lock backing out of the driveway, but not on the fenders, and the 19's never rubbed in any situation that i noticed
Old 11-28-2008, 08:16 PM
Thanks for the info; this definitely helps making the choice easier!
The rubbing I take it was on the front at full lock?
I had this same 'problem' with my Golf with H&R cup kit - it would rub on the fender liner, but not on the fender itself. It didn't rub unless it was a serious bump, during full lock, or both simultaneously.
-Steve
Old 11-29-2008, 10:27 AM
Squirrel Czar
exactly, it rubs on the liner at full lock, the tires are also taller bigger in overall diameter on my stock wheels, the 19's with the 35 profile tires are just slightly less in total diameter.
Members: 2,469
Threads: 5,422
Newest Member: rubski
