Go Back   SUPERNISSANS.NET Nissan Owners Community > VEHICLE TECHNICAL DISCUSSION > Nissan Specialty/NEW Model Discussion
Old 04-28-2008, 05:17 PM
RLR Is Coming Soon
Red Lion is on a distinguished road
Default V-spec Vid (or Spec V?) Vid
Not to mention some info on the new GTR Spec
Best Car sheds even more light on the Nissan GT-R Spec V…
Back on April 7th a development team from Nissan Japan arrived at Nurburgring in Germany to commence testing of the GT-R Spec V with the intent of lapping the famous circuit around the 7 to 8 minute mark. The test car featured carbon brake disks and larger silver 6-piston brake calipers, which along with some RAYS Engineering 20 inch alloy wheels, redesigned carbon front lip spoiler and carbon rear spoiler combined to produce a level of grip and stopping power a step above the standard GT-R. Just prior to this in mid-March, the Spec V test car was seen running at Sendai Highland circuit undergoing rigorous braking tests from very high speed in order to prepare the car for the Nurburgring tests.
At around 4pm on April 8th and with unfavorable conditions, the GT-R Spec V produced a lap time (recorded by observers) at the ‘Ring of 7 minutes 25 seconds. The target time for the Spec V was a slightly more optimistic 7 minutes 20 seconds but with a damp track this wasn’t to be realized. To put it into perspective, last year Walter Rohrl piloted a Porsche 997 GT2 at the same track and completed a lap time of 7 minutes 32 seconds, some seven seconds slower than the Spec V. Even more surprising is the gap in lap times between the standard GT-R and the Spec V, the regular model posting a thirteen second slower lap time at 7 minutes 38 seconds. Spec V test driver Toshio Suzuki suggests that given the right conditions the Spec V could very well produce a lap time that could “blow ones mind”. Following the April 8th tests the GT-R Spec V was taken from the Nurburgring circuit temporarily and switched to general road tests.
It has been pointed out that in order to prevent warping of the hood at high speeds of around 300km/h, it was necessary when designing the R35 GT-R to incorporate its now trademark ‘winglets’ on either side of the front bumper. These winglets are still visible on the GT-R Spec V and have not yet made way for the two air intakes we mentioned in our previous article. The front lip spoiler and rear wing are still undergoing tests to achieve excellent front and rear balance but in order to keep drag to a minimum they are unlikely to be changed much from their present design.
A source close to the Nissan development team has confirmed that the Spec V has an unladen weight of 1590kg and a power output of 550ps, but made no mention of an ‘over boost’ function as reported in our previous article. A power improvement of 80ps and a weight reduction of 150kg puts the power to weight ratio at 2.89kg/ps which puts the GT-R Spec V in another league. These figures will likely help the Spec V achieve a ten second 0 - 400m time, a good improvement over the already quick 11.6 second quarter mile of the standard car.
We’ve also got some new information concerning parts you can’t see from the photos of the Spec V.:
The rear diffuser has been changed to a carbon fiber item with a NACA duct added as an exit point for heat that builds up towards the rear of the exhaust near the mufflers.
A stainless steel exhaust system has been used until now to check for signs of weakness in the structure of the exhaust system and points of extreme high temperature. This will be changed to a more heat resistant and lighter titanium item in keeping with the Spec V’s weight reduction plan.
Will debut in October this year.
With the abundant use of carbon fiber and titanium we can expect the Spec V to sell at around 13,000,000 yen.
Old 05-05-2008, 05:37 PM
amazingcodes is on a distinguished road
Very Usefull information
