Old 09-29-2008, 05:36 PM
Black Dragon's Avatar
Black Dragon will become famous soon enoughBlack Dragon will become famous soon enough
Default Anyone know how to program the remote fob?
I just picked-up a new remote fob for my '02 Altima, after losing my set of keys recently. (Saved over $100 by going through e-bay, versus the stealership.)
I understand I don't have to go to the stealership to program it and can be done by myself. Does anyone know how to do this?
Thanks in advance for your help...
Old 09-29-2008, 05:48 PM
sergey85's Avatar
sergey85 will become famous soon enough
Send a message via AIM to sergey85
have u tried disconnecting the battery for like 30min.?
2002 Maxima GLE Silver on Black | Berk Intake w/AEM Dryflow | Clear Sidemarker Lights w/PIAA L.E.D|Fibre Customs EyeLids | PIAA White Fogs | 5% Limo Tint | Brembo Blanks and Hawk HPS Pads |CATTMAN RSB| ebay FSTB | NWP VIAS Block Plate |
not installed:
Phenolic Thermal Intake Manifold Spacer Kit | 07 350z rims (needs tires)| OEM spoiler(paint)
Old 09-29-2008, 05:51 PM
its something like insert key and turn to on for 5 seconds, then off and remove and insert key 10 times, then push the buttons on the keyfob.....let me look for it....
Old 09-29-2008, 06:03 PM
Found this.....this is how I reprogrammed my keyfobs in my 02 QX4.....
REPROGRAM KEY FOB
QX4, 1997-2004 Q45, I30, I35,1999-2002 G20, FX, G35, M45, Most Nissan Vehicles
The horn chirp can be disable by pressing the lock and unlock buttons simultaneously until the hazard lights flash, and no enable press the lock and unlock until the horn chirp.
To reprogram (enter new ID) key fob (keyless remote controller) follow the steps.
1. Close all doors and lock all doors
2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds.
(The hazard warning lamp will then flash.)
NOTE:
Key should be withdrawn from ignition key cylinder completely each time.
NOTE:
Do not rush the insertion/removal key cycling process. The side
marker/tail/license lamps and interior illumination will flash twice when this step is
accurately completed.
3. Insert key on ignition key cylinder and turn ignition key switch to "AAC" position
At this time, the new ID code is entered and original (previous) ID codes are erase.
4. Press any button on the new remote controller once. (The hazard warning lamp will then flash)
NOTE:
Do not press the button more than one time in the above step. If the button
is pressed more than one time, the programming procedure will not be successful.
The side marker/tail/license lamps and interior illumination will flash twice when this
step is accurately completed and programming is successful.
If there is only one remote controller skip step 5.
5. Additional ID code entry
Release the door lock, then lock again with door lock/unlock switch
(In power window main switch)
6. Remove key from ignition
7. Unlock driver side door, open driver side door and then close the door. (END)
NOTE:
If you need to activate more than two additional new remote controllers, repeat
the procedure on step 5 "Additional ID code entry" for each new remote controller.
NOTE:
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignore.
Did not work? Try these steps
Old 09-29-2008, 06:22 PM
^^^cool. i'll go try this, thanks!
Old 09-29-2008, 07:04 PM
sergey85's Avatar
u should make that a sticky sassan i bet alot of people could use that
Old 09-29-2008, 09:53 PM
thanks sassan! works like a charm...
Old 09-30-2008, 11:33 AM
Answering from my phone, but I will. I bought my keyfobs from ebay, and these are the instructions that came with it.
Glad it worked.
Old 12-16-2008, 12:55 PM
Sf2fan's Avatar
Sf2fan is on a distinguished road
Send a message via ICQ to Sf2fan Send a message via MSN to Sf2fan
What is considered a good price on Ebay for these FOBs? I need to purchase 1 for my new ride.
Old 12-23-2008, 12:56 AM
I paid less than $20 for mine....
Old 01-15-2009, 04:52 PM
allicedout's Avatar
allicedout is on a distinguished road
I Paid $12 for mine off ebay, programmed as above worked like a charm!
Old 02-01-2009, 05:36 AM
I use this on my keyfob too:
eBay Store - Key Fob Cover: Category 1
eBay Motors: Infiniti Key Fob Cover, QX4, Q45, QX56, M45, G35 (item 280270728695 end time Feb-21-09 09:54:47 PST)
This way, my actual keyfob never gets damaged. Its a protective cover for less than $10.
Old 10-31-2009, 11:29 AM
lankythekid is on a distinguished road
Sorry to bring this thread back to life.
But can you use any Nissan key fob for example the Sentra or Maxima ? Or does it have to be an Altima fob?
Old 11-01-2009, 07:34 AM
Honda Sucks
wild willy is just really nicewild willy is just really nicewild willy is just really nicewild willy is just really nice
Good post, great Info!
12 Altima SR
12 Quest SL
91 MR2
04 Honda Oddy (POS)-GONE!!
Old 11-03-2009, 10:34 PM
You know, I am not sure. Never tried any other keyfobs. Sorry
Members: 9,327
Threads: 9,321
Newest Member: brandonswindell
