Go Back   SUPERNISSANS.NET Nissan Owners Community > VEHICLE TECHNICAL DISCUSSION > Nissan Altima Technical Discussion
Old 09-11-2008, 09:28 AM
dsuave624's Avatar
dsuave624 has a spectacular aura aboutdsuave624 has a spectacular aura aboutdsuave624 has a spectacular aura about
Default How to: Removing Front Bumper
Removing the Bumper on the Altima is a relatively easy job, however, it is a major pain in the ass. Unfortunately, it is required for a lot of other various modifications to the car so mastering it will be useful.
The first time around will be frustrating, annoying and will probably take 30-40 minutes. After that, it will take no more than 15.
1. Jack the car up from the front so that both tires are off the ground. (Make sure your e-brake is on and you have some kind of blocks behind the rear tires)
2. On the bottom, near the sides, there are two (2) ‘stubby’ Philips screws that connect the bumper to the plastic cover under the engine. Remove those on each side.
3. Remove the five (5) plastic fastener clips that connect the bumper to the rest of the plastic engine cover. You can use a flathead screwdriver for that. Be careful because these clips are cheap and can break easily. If that happens, you can go to Nissan and buy replacements for cheap.
At this point, the engine cover should be completely free from the bumper.
4. If you have fog lights, pull the engine cover down and disconnect the wires from the bulbs.
5. Remove both front tires. This step is optional but I highly recommend it as it makes step 6 MUCH easier.
6. In the wheel well there is a plastic cover that protects the engine from water and debris from the tire. With the bottom cover loose, pull this cover towards the rear of the car (don’t break it) and expose that area. Look for two (2) screws that connect the bumper to the fender. There is one screw towards the tire and another near the headlight. Use a Philips screwdriver to remove those (2) screws.
Repeat on the other side.
This is the most difficult step simply because of the access you have and it’s hard to see.
At this point, the bumper should be hanging from the top.
7. There are six (6) plastic fasteners clips securing the bumper from the top. Remove those with a flathead screw driver.
8. The bumper should now be free for you to remove.
Pics courtesy of some other Nissan owner that I do not know...LOL
Old 09-11-2008, 04:43 PM
Spike's Avatar
ST 38
Spike is on a distinguished road
Nice write up. I've always been too damn lazy to do a write up for this but have been asked numerous times on how to do it.
Cardomain
Mods:
| Apexi V2 | Hella Optilux 1180 / Prolumen 3000k | Polk DB6500 + Polk DB690 | SE- R Tails | Helios 5000k | LED interior lights | Polk Momo C400.4 | SE-R front | Racingline FSTB | Nismo Catback | SE-R Rear | AT S5 | Nismo 57F / Potenza RE01R; 245 45 18 | Redline Quicklift Elite | Hotshot header | Jihad folding mirrors | SE-R replica spoiler | Nismo RSB | Audi DRL | Tein SS w/ EDFC |
Soon: | 300zx BBK | A4 fender marker |
Old 09-12-2008, 01:35 AM
QR QR is offline
yay
QR has a spectacular aura aboutQR has a spectacular aura about
Send a message via AIM to QR
sticky?
Members: 9,130
Threads: 9,091
Newest Member: ernestnworley
