Go Back   SUPERNISSANS.NET Nissan Owners Community > VEHICLE TECHNICAL DISCUSSION > Infiniti Current & Past Models Technical Discussion
Old 03-22-2008, 02:39 AM
Power of knowledge is on a distinguished road
Default Navigation problem I am having
I recently purchased a 2004 G35 Coupe and can not get the navigation system to calculate a route. I get an error message when I select an address or nearby point of interest - "route was not succesfully calculated." Everything else seems to be working, map display, where am I, listing of addresses and POI's, and even the green status bar is visible (and moving) while the nav system is "trying" to calculate the route.
I have reviewed the navigation system manual but could not seem to find the issue and fix. I feel like this is a trival matter and I am overlooking something simple but have not had any luck yet. Any help or suggestions would be appreciated. Thanks.
Old 06-07-2008, 07:42 AM
MaDd's Avatar
MaDd is on a distinguished road
odd.. i've had that problem once or twice in my old G but a simple restarting of the car fixed it.
is the navigation cd scratched? sounds like a software issue. if its a hardware issue resetting the car by unplugging the battery might help. those are just my guesses
2008 G37s Ivory Pearl/Graphite / 6spd / Premium Package / Sport Package / Technology Package / Navigation / Spoiler
Old 07-07-2008, 06:20 PM
superblackz's Avatar
superblackz is on a distinguished road
Flash the firmware on the unit with the most recent disk. Check around, if you don't have the DVD's you should be able to track them down outside the dealership. It uses a dual-layer DVD, so be careful of people who make copies of the originals, it has to be done with a dual-layer DVD writer.
Another possibility is someone mixed map disk version with wrong firmware - they have to match. I don't have the specific version numbers memorized, but I do know they cannot be mixed.
If you're getting a green color on the satellite pic on the display, then the receiver is working. You can also check under the settings for the NAV and see the specific number of signals you're getting.
If that's not working, then you have mechanical, not software problems.
'91 B13 Black, JDM 10:1 CR SR20DE, Custom Intake/MAF, 2.5" SSAC Header, Progress Coil-overs 350F/250/R, 3-way adj. 30-mm Progress FSWB, 22-mm Progress Rear Sway, Ground Control Camber Plates, Front strut and FW braces, Progress control arm brace, Energy Suspension bushings, Wilwood Brakes, 4.4 kg Motegei Traklites 15x7, Kuhmo MX tires.
