Go Back   SUPERNISSANS.NET Nissan Owners Community > TECHNICAL/RACING FORUM > ICE Audio/video/GPS Discussion
Old 06-03-2008, 12:15 AM
Jose3.5's Avatar
Ticket Magnet
Jose3.5 is on a distinguished road
Send a message via AIM to Jose3.5 Send a message via MSN to Jose3.5 Send a message via Yahoo to Jose3.5
Default Whining Noise
So I have this whining noise coming from my speakers when I accelerate, any ideas on how to get rid of it? I can only hear it at low volumes.
2007 Altima 3.5 SE CVT
Old 06-03-2008, 12:49 PM
ManicSquirrel's Avatar
Get off my nuts
ManicSquirrel will become famous soon enough
that's a new one jose, i can't imagine how the 2 are related, the accelerating and the speakers, unless there is some odd electrical issue going on there. maybe another issue with the d3?
2007 3.5SL (loaded, with tech package) Radiant Silver : Nismo cat-back : Injen WAI : 35% tint : 19" x 8.5" Enkei RP03's/Goodyear Eagle F1 All Seasons : Eibach Pro-Kit Springs: PIAA plasma ion yellow fogs : stealth turn signal bulbs
Originally Posted by QR [Only Registered Users Can See LinksClick Here To Register]
when i was a little kid and when my dad used to get mad at me he'd tell me that i'm a mexican that got switched at hospital on accident.
Old 06-03-2008, 07:41 PM
Jose3.5's Avatar
Ticket Magnet
The two 6 1/2's and the 6x9's are powered by an amp and I'm not sure how much power is running into them. I have to 12" Kicker CVR subs but thats not the problem because the noise was there before I put them in.
Old 06-03-2008, 07:56 PM
carfreak67 is on a distinguished road
Sounds like a ground issue.
Somewhere either you are not grounded properly or one of your speaker/line inputs into your amps has managed to ground itself out.
Double check all of your speaker and line-in connections to your amp(s).
If everything is looks good try unplugging the line-in RCAs one at a time until it goes away. If it does then you will know which one is grounding out.
If it stays there then try disconnecting your speak outputs one at a time until you can isolate it.
Old 06-03-2008, 08:36 PM
Jose3.5's Avatar
Ticket Magnet
I'll try that this week end and see what happens. I also get a lot of white noise.
Old 06-03-2008, 09:58 PM
sergey85's Avatar
sergey85 will become famous soon enough
Send a message via AIM to sergey85
are u sure its not your alternator
2002 Maxima GLE Silver on Black | Berk Intake w/AEM Dryflow | Clear Sidemarker Lights w/PIAA L.E.D|Fibre Customs EyeLids | PIAA White Fogs | 5% Limo Tint | Brembo Blanks and Hawk HPS Pads |CATTMAN RSB| ebay FSTB | NWP VIAS Block Plate |
not installed:
Phenolic Thermal Intake Manifold Spacer Kit | 07 350z rims (needs tires)| OEM spoiler(paint)
Old 06-03-2008, 11:03 PM
Jose3.5's Avatar
Ticket Magnet
It started doing it when the new speakers and amp were installed.
Old 06-04-2008, 12:48 PM
Not too long after I installed my system I had one of my RCAs start touching a metal bar behind the dash and that grounding out gave me a whirring or whining noise that changed pitch with engine RPM.
Since all of my RCAs had metal connectors I had to wrap all of them in electrical tape to make sure none of them would ground out and cause problems down the road.
Old 06-04-2008, 05:13 PM
Jose3.5's Avatar
Ticket Magnet
Its driving me nuts, hopefully I'll be able to figure it out this weekend.
Old 06-11-2008, 01:20 AM
Sassan is a jewel in the roughSassan is a jewel in the roughSassan is a jewel in the roughSassan is a jewel in the rough
you know, after reading your thread about the battery dying, I am convinved your alternator is not holding up.
Old 08-24-2008, 08:48 PM
atl530i's Avatar
atl530i is on a distinguished road
You have a ground look issue. My Altima has the same problem. I re-ran my RCAs away from any power wire and moved the slack away from the power wire for my amp, that solved the problem. If all else fails, get some ground loop isolators and you should be set. Sound quality may go down very little but it is such a small difference that you will not even be able to tell. Old post but I did not see any posts that really solved your issue. That whine is your alternator as well.
What model amp are you running and how good of quality of RCAs do you have?
[Only Registered Users Can See LinksClick Here To Register] - BMWCCA #364056 - [Only Registered Users Can See LinksClick Here To Register]
1994 BMW 530iA - 1981 BMW 528i5 rip - 2001 Nissan Altima
Old 08-24-2008, 10:37 PM
Jose3.5's Avatar
Ticket Magnet
The RCA's are Scosche or how ever its spelled and it's a Rockford Fosgate amp. I haven't tried to fix it, all I do is turn up the music louder and it goes away. I can only hear it at lower volume levels.
Old 08-24-2008, 11:41 PM
atl530i's Avatar
Get some good Monster or Stinger RCAs. I had a real bad whine in my BMW and monster cables fixed that. I swear by Monster now and they are worth it if you are looking at getting zero noise.
Old 08-25-2008, 02:17 AM
