Disclaimer: Long and confusing post. ;)
Tonight I felt the need to tackle an issue I've been having since my aftermarket deck got stolen.
the loss of signal to the rear speakers.
Since the theft some time ago, I had since re-installed the factory CD/Tape/radio.
After removing my deck from the center console I soon realized that there is a connector missing.
There should be two white connectors one 10pin and one 6 pin. I currently have the 10 pin intact but apparently missing the 6pin. Of which I assume is still attached to my former deck in the hands of some thief. ;)
After some digging around I came upon something rather confusing. (the point of the thread)
Brief history: I bought my car used back in 03 from the dealer. It had aftermarket speakers in both the front and rear as well as some aftermarket wires.
I wanted to see what was going on with these wires, after studying the wiring diagram from my FSM, something wasn't adding up.
I started by following the sends out of the 10pin connector for the deck, first being the Front Right and Front Left sends which are spliced into aftermarket wires that are ran all to the rear of the vehicle and spliced into the factory wires marked for the rears respective to Right and Left.
I return to the front console area to find that the other end of the Factory rear wires are spliced to the respective R/L leads to the front speakers. ( the original factory wires had been cut if you are confused.) Its like they made the front sends REALLY LONG. WHY?
Also there are 2 sets of loose aftermarket sends routed from the front to the rear and connected to the rear speakers. I assume these are the ends that are for the 6pin connector which is for the rear speakers. (the one I'm missing)
Note: I assume the above is correct regarding the connection of aftermarket wires because its the only plausible scenario I can come up with. Also I didn't actually check the lines to be certain, didn't want to jmmy-rig the voltmeter to reach from the front to rear. ;)
So with all that said. Whats the POINT of the second set of aftermarket wires? Why the long send? Am I missing something? Did i Confuse you?
BTW. I've reconnected all the wires to their respective mates. As if it was back to stock. I'm just curious if i was missing some special setup or if the owner before me was on something when doing their setup.
