Go Back   SUPERNISSANS.NET Nissan Owners Community > SUPERNISSANS BAZAAR > Group Buys/Vendor Sales
Old 10-24-2008, 03:01 PM
Aaron92SE's Avatar
NWP Engineering - Vendor
Aaron92SE is on a distinguished road
Send a message via AIM to Aaron92SE Send a message via Yahoo to Aaron92SE
Default Thermal Phenolic Intake Spacer Kits - ELIMINATE HEAT SOAK!! - 10hp and 12ft-lb GAIN!!
NWP Engineering Phenolic Thermal Intake Spacer Kits
Applications:
1995 - 1999 Nissan Maxima (3L DOHC V6 VQ30DE)
2002 - 2003 Nissan Maxima (5th generation 3.5L DOHC V6 VQ35DE w/o EGR)
2004 - 2008 Nissan Maxima (6th generation 3.5L DOHC V6 VQ35DE with EGR)
2002 - 2006 Nissan Altima (3.5L DOHC V6 VQ35DE)
2003 - 2007 Nissan Murano (3.5L DOHC V6 VQ35DE)
2004 - 2008 Nissan Quest (3.5L DOHC V6 VQ35DE)
2002 - 2004 Infiniti I35 (3.5L DOHC V6 VQ35DE)
1989 - 1994 Nissan Maxima (3L SOHC V6 VG30E)
1992 - 1994 Nissan Maxima SE (3L DOHC V6 VE30DE)
Below are the 5 spacers included in the VQ35DE Kit:
All NWP Engineering Thermal Intake Spacer Kits include the hardware and lengthened bolts needed to do the entire install. Also included are full installation instructions with pictures.
The VQ35DE kit consists of the following:
- TWO 1/16" High Quality CNC Machined Phenolic Intake Manifold Spacers (Lower Intake Manifold)
- 1/4" High Quality CNC Machined Phenolic Intake Manifold Lower Collector Spacer (Upper Intake Manifold)
- 1/4" High Quality CNC Machined Phenolic Intake Manifold Upper Collector Spacer (Elbow)
- 1/4" High Quality CNC Machined Phenolic Throttle Actuator Spacer (Throttle Body)
- Intake Manifold Upper Collector Coolant Bypass Fitting
- 4 Lengthened High Quality Zinc Plated Grade 8 Throttle Body bolts and washers
- 4 Lengthened High Quality Zinc Plated Grade 8 Elbow bolts and washers
- 3 Lengthened High Quality Zinc Plated Grade 8 Upper Intake Manifold bolts and washers
- 2 Lengthened High Quality Zinc Plated Grade 8 Upper Intake Manifold offset studs
- Printed Detailed Installation Instructions with Photos- Two Die Cut Silver Vinyl NWP Engineering Decals
Comes with everything pictured (VQ35DE Kit):
All of NWP Spacers are port matched to ensure the best airflow possible. And all OEM intake manifold gaskets are completely eliminated resulting in better airflow!
CNC Machined to the highest tolerances for the best fitment possible:
10hp and 12ft-lbs of torque below 5K rpm!
40 degree intake manifold temp drop!
See what others are saying [Only Registered Users Can See LinksClick Here To Register] and [Only Registered Users Can See LinksClick Here To Register]!
All 3.5L kits are $225 plus $10.00 S&H. The 4th gen (95-99) Maxima Kits are $215 plus $10 S&H. The VE30DE and VG30E Maxima kits are $145 plus $10.00 S&H.
Please order at [Only Registered Users Can See LinksClick Here To Register]. If you want to pay with a money order or are located outside the continental US, please contact me directly before ordering!
All packages will ship within one business day. All packages are shipped via insured USPS 2-3 day Priority Mail with Delivery Confirmation.
If you have ANY questions, please do not hesitate to contact me directly or post in this thread.
Thank you,
Aaron Kimball
NWP Engineering, Inc.
252-747-7672
[aaron@nwpengineering.com]
NWP Engineering Phenolic Thermal Intake Spacers
10hp and 12ft-lb gain & 40°F temp drop on the VQ35DE
Old 11-14-2008, 10:06 PM
Aaron92SE's Avatar
Still in stock and ready for immediate shipment.
Old 12-15-2008, 12:43 PM
Aaron92SE's Avatar
Bump!
Old 01-05-2009, 09:25 PM
johnnyd2k2 will become famous soon enough
Bump for some great stuff one of my favorite mods!
