Has your KA finally put you to sleep, or has the tired/slow revving truck motor seen better days??? If so, than you’re probably looking to take the next step in power, (and no, it’s not KA-T) which is obviously the SR20DET!
Just like the KA-T guide, this list is one primarily there for you to make the final call on what parts you decide to use on your car. I’ll try to provide basic info and give proper examples, but ultimately it’s your pocket book that is going to determine what part you get in the end.
This also isn’t intended to be a guide on how to swap one into your car. I will provide those links in the engine section below.
Now, on with the juice!
ENGINE: SR20DET
First off, we’ll start with some specs on the different engines and the sort (Sourced from Heavy Throttle)
*S13 Redtop Engine*
180SX 91-93 and Silvia 91-93
Displacement: 1998cc (2.0 liter)
Cam type: DOHC 16 valve, chain driven cam sprockets
Bore and stroke: 86mm x 86mm
Compression: 8.5 : 1
Horsepower: 205ps at 6000rpm Torque: 203 ft/lbs at 4000rpm
Stock boost: 7 psi
Throttle body bore: 60mm
Turbo specs: Injector size: 370cc/min
Compressor: T-25, 60 trim 56mm BCI-1 compressor.
Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing.
*S13 Blacktop*
180SX 94-98
Horsepower: 205hp at 6000rpm Torque: 203 ft/lbs at 4000rpm
Stock boost: 7 psi
*S14 Notch top*
Silvia 95-98
Horsepower: 220hp at 6000rpm Torque: 203 ft/lbs at 4800rpm
Turbo specs:
Compressor: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing
Center Section: Ball Bearing
Variable valve timing system and a different turbo are the significant changes from the S13 SR20DET engines. S14 uses 'low port' intake design vs. S13 'high port' design.
*S15*
S15 Silvia 99+
Horsepower: 250ps at 6000rpm Transmission: 6 Speed, Close Ratio
Injector size: 480cc/min
Turbo specs:
Turbine: Inco turbine wheel. Cast divider wall between turbine discharge and wastegate.
Additions: 6 speed manual transmission. The 6 speed cannot be used on the S13 and S14 motors, and uses a different driveshaft. Speed sensor is located in the differential.
As with all engines, the newer the better when it comes to the SR. This doesn’t mean that the s13 redtops are bad engines, it’s just that they are slowly becoming older and older, hence making it more of a requirement to rebuild all s13 engines, or at minimum change seals and bearings, but you should do this even with newer engines.
With the SR becoming more and more popular, the sources for engines have increased ten fold. With this increase however, comes the countless scams that can be found online and especially on eBay. While we’d all love to find a ‘perfect low mileage’ redtop for 1300, it just doesn’t happen. While deals can be found/hand, it’s more than likely that you won’t find a complete redtop motor set for less than 2,000 dollars. Obviously you may be able to purchase them junk and rebuild them for less, but this is just a ‘ballpark’ estimate for a true ‘drop in and go’ engine.
With all JDM engine swaps, it’s usually a case of high cost=high quality. Because of that, the following places are the ONLY places you should get your engine from. These places all have great customer service, and will not lead you wrong:
1.Heavy Throttle, of New York (
[Only Registered Users Can See LinksClick Here To Register] )
2.Phase 2 Motortrend, of Southern California (
3.Enjuku Racing, of South Florida (
4.SR20Store,
Again, while there may be others that are good, these 3 are time tested and proven to deliver the goods.
As with all engines, I highly suggest purchasing an OEM gasket rebuild kit for both top and bottom ends. New OEM bearings are another thing to replace. Other things to change while the engine is out of the car are the water pump and oil pan.
SWAPPING KA FOR SR
Again, I said earlier that this wouldn’t be a swap guide, mainly because there are already good ones out there. Below is a list and description of where to go for what when it comes to your engine quest: Probably the best swap guide on the net, direct from Heavy Throttle:
TURBOCHARGERS:
As the quest for more power continues, one of the next stops is upgrading turbos. With proper mods, S14 T28’s are known to put cars into the 270 whp category, however some people will still thirst for a faster car. S15 Silvia turbos could put 300whp with equal mods.
Now if you’re looking for something aftermarket, and or new, there are many good options. For those looking to stay t2 based and retain stock manifolds, there are 4 (well 5 kind of) great upgrade turbos: HKS GT-RS, Garrett GT28RS (Disco Potato), and the newcomer, Garrett GT2871r (Either .64 or .86). The HKS GT-RS and the Disco Potato are fantastic torque monsters, and are noted for their lightning spool ability. Fun street turbos, these will give approximately 320-330 peak power with appropriate mods at 18-20 psi. Not a lot, however it’s the instant spool ability that sells these turbos. 10 psi on a disco will eat up 12 on a t3/t4 ka, simply because of response.
The 3rd turbo (or 3rd and 4th) is the GT2871r. Now the .64 turbine version is slowly becoming the logical upgrade over the 28RS, as it provides damn near similar spool time, however where the disco falls of at 6000 rpm, the 2871 pulls hard to the limiter. With proper setups, the 2871 .64 is putting down between 360-380 whp at 18-20 psi. This translates to high 11’s on street tires in the 1320. The big brother to the .64 turbine is the .86 option. This turbo has a slight bit more lag/onset than the previous 3 (still not as bad as a t3/t4), but where this lacks in response, it makes up for in top end. 400hp whp dynos are common with the right parts. Lastly is the 3071r. This is the largest t2 available from Garrett. This will have similar lag to a t3/t4 setup, but provide more power than the 2871r .86. People looking for highway monsters, check here!
For those looking for t3 based turbos, there are many great upgrade choices. Obviously, the proven old guy of the group is the typical t3/t04e turbo. Found in countless varieties, it can be basically crafted to ones own personal taste. One of the most popular t3/t4’s out there is the Precision SC61BB. Regarded as the fastest spooling t3 hybrid, it’s proven to throw down huge numbers and make legends out of ‘wangan’ (highway) rollers. Fear not Garrett standbys: Garrett has just release ball bearing CHRA upgrades for those that already have old units. These upgrade options should make for VERY interesting times when those begin to convert over. GT3076 and GT30r’s also provide big power, and are great t3/t4’s for those with the peak power craving.
Again, while other turbos may be available, such as GT35, GT32, and T66’s the fact of the matter is that those going that route aren’t new guys, and have more than enough knowledge to go that far.
As before, purchasing a turbo isn’t tricky, but down to preference. Want fast spool, response and the ability to drop your sisters panties quicker than the football team captain, go gt2871r .64! Want power that will make you a highway KING, and get you pussy you never knew available before, follow the ‘go big or go home’ mantra and get yourself a SC61BB.
Interested in getting one, check out the following:
Also be sure to check other for sale forums for great deals on these turbos.
MANIFOLDS and TURBO EXTENSIONS:
Manifolds are always a topic of discussion for those looking for great power. Obviously manifold choice is co-dependent on turbo selection, so be sure to get the correct flanges for your setup. Those opting for t2 based fun; you can keep the stock OEM cast manifold on there for durability and proven performance. There are also countless bottom mount t2 tubular turbo headers to choose from. HKS, and JIC are many of the choices to go from. Remember, while Name Brand is proven to last longest without cracking, one can always opt for cheaper alternatives like the Megan racing if looking for the look, and bang for buck.
T3 based ballers will have to look no further than Full Race or Peakboost for manifold options. While pricey, they are both regarded as being the best.
Lastly, if you’re looking for aftermarket turbo extensions (also known as o2 housings, or J pipes), look no further than the Greddy or HKS housings. High quality, with split tracts for wastegate gas and normal exhaust, these units are dyno proven to be the best. Cheaper alternatives are available, but go with the best on this one.
