Go Back   SUPERNISSANS.NET Nissan Owners Community > VEHICLE TECHNICAL DISCUSSION > Nissan Altima Technical Discussion > (2007-2010+) Nissan Altima Tech. Discussion (4th gen)
Old 01-24-2009, 12:21 PM
ManicSquirrel's Avatar
Squirrel Czar
ManicSquirrel will become famous soon enoughManicSquirrel will become famous soon enough
Default Brake pads
So i've got about 20K miles on my car now, and seem to be getting some squeal now and again and a little rougher braking, time for pads?
also one more quick question. When i am in a drive through with the driver's side facing the wall and the window down, when the car is rolling it almost sounds like there is a light rubbing or something coming from near the front left wheel area. not like a tire rub, almost a mechanical type rub, maybe a bearing or something? maybe the brakes?
2007 3.5SL (with tech package) Radiant Silver : Nismo cat-back : Injen WAI : 35% tint : 19" x 8.5" Enkei RP03's/Bridgestone RE050A 245/40-19 : Eibach Pro-Kit Springs: PIAA plasma ion yellow fogs : stealth turn signal bulbs
Old 01-26-2009, 11:57 PM
carfreak67 will become famous soon enough
You should only need brakes after 20K miles if you really beat on your car.
Otherwise, your brakes should last at least 40K.
But from the noise you described I would pull the wheels and give the brakes a look-see just to make sure you don't have a sticky caliper that caused your pads to wear prematurely.
BTW a buildup of brake dust on your calipers and rotors can cause minor squeaking.
Democracy and socialism have nothing in common but one word, equality. But notice the difference: while democracy seeks equality in liberty, socialism seeks equality in restraint and servitude. -Alexis de Tocqueville
Old 01-27-2009, 12:18 AM
Squirrel Czar
i don't drive very hard normally, a lot of highway, but a lot of stop and go traffic, and a lot of hilly country roads. I know some with the 4th gen's have had pads needing replaced early though. They only squeak maybe once every couple of times i drive it, and only right before coming to a stop, and usually it seems to be in a situation where i would have some dust build up.
i'm used to most of the gm's i owned needing rotors turned every 10K miles...so brakes make me paranoid.
Moral of the story, i'm glad a question actually got answered in the tech forum. now how about that creak i get from the wheel well area when the wheel has to be turned full lock in a tight parking situation?
Old 01-27-2009, 04:48 PM
That creak is most likely the turn stop adjustment bolt rubbing on the control arm.
There are bolts that can be adjusted to limit your wheel turn angle when locked one direction or the other.
The head of the bolt contacts a portion of the control are and prevents the wheel/hub assembly from turning too far and causing damage.
When the steering wheel is held in the fully locked position this bolt is pressed against the control arm. Even if the suspension moves very slightly it will cause the bolt to move up or down against the control arm and it may produce a squeak or a groaning noise.
Just don't hold the wheel fully locked to the left or right and you'll never hear the noise.
It's a common noise on just about any vehicle.
Old 01-27-2009, 04:57 PM
Squirrel Czar
Originally Posted by carfreak67 [Only Registered Users Can See LinksClick Here To Register]
awesome ,that describes it perfectly when i think about when it does it and on what surfaces. Thanks
Old 01-30-2009, 10:27 PM
Ticket Magnet
Jose3.5 is on a distinguished road
Send a message via AIM to Jose3.5 Send a message via MSN to Jose3.5 Send a message via Yahoo to Jose3.5
Nissan brake pads are shit. Mine wore out at 12k and now I'm 17k and it feels like they're gone also.
2007 Altima 3.5 SE CVT
Old 01-30-2009, 10:31 PM
Squirrel Czar
that's insane really
Old 01-30-2009, 10:58 PM
Ticket Magnet
Yeah, I'll get something else next time.
Members: 2,464
Threads: 5,418
Newest Member: jj730
