Specifications and Performance
Nissan Altima Hybrid – Braille Battery “Hot Rod Hybrid” Race Car
Weight 2970.5 pounds (3485 stock)
“Hot Rod Hybrid” System: 2.5 Liter Inline 4 Cylinder – Ethanol E85 Fuel Permanent Magnet AC Synchronous – Braille Battery Powered
“Hot Rod Hybrid” Horsepower* 440 HP
Modifications – Ethanol E85* Vortech Electric Supercharger DCHSEO-P1
Modifications – Electric Drive* Braille Battery Carbon Racing Pack – Phase 1 Experimental
Horsepower Peak – Ethanol E85* 270 HP @ Crank / 270 @ Crank - Estimated
Torque – Electric* 240 lb/ft @ 0 – 1500 rpm, Voltage 650 Volt Max
Battery Charging Regeneration Technology, Solar Panel Charging System
Transmission Electronically Controlled Continuously Variable Transmission
Chassis Unitized body construction with TIG Welded 6 Point Racing Cage
Suspension BC Racing Aluminum Coil Over Suspension, Stillen Sway Bar
Brakes Wilwood Lightweight Vented Disk w 4-channel ABS
Seats Sparco “ECO2009” Made from waste materials, FIA Approved
Steering Wheel Sparco 360 Suede Wheel
Wheels Front/Rear: 18 x 9 Enkei Lightweight LF-10 Rims
Tires Front/Rear: 255/40 18” Yokohama Low Rolling Resistance Neova High Performance Tires
Acceleration Quarter Mile* 12.9 sec. @ 109.2 mph estimated
Lateral Acceleration* 1.02 g
Braking: 60-0* 97 feet
Racing Fuel Economy* 35 laps at Sebring vs. 20 Laps at Sebring for Non-Hybrid
* Unverified Data. Information Calculated on Individual Manufacturers Specifications
I wonder what kind of splitter that is and if I can fit in on my car
