I just picked up an '08' Altima 2.5SL w/ connection pkg.
Is there a way to add a small sub to the existing Bose system, possibly using the existing amp. I just want to add a little more thump to the existing system without spending a fortune.
yeah... its been done before... I think you need an adapter (Soche?) since its Bose...
check out crutchfield.com .... you can put in that you have Bose and look around... or give them a call... Good Luck...
There is no way to power a sub off of the stock bose amp. what you can do is add a standard amp/sub package. you will need a line level converter to convert the speaker level signals from the rear speakers to a preout level needed to supply the amp. you're looking to spend at least $300.
