Just carrying this over from NC:
I am making this write up for people who are electronic literate. If you know nothing about soldering or electronics, do a little reading first. I am not going to do a step by step thing for dummies here, there are too many details to cover if I do this. Also, please keep in mind that the BCM is EXTREMELY expensive and that you are actually going to be screwing around with it if you choose to do the dome light part. If you screw up the BCM, prepare for a lot of hell.
Tools needed:
Soldering iron
Solder (i recommend using a tin/lead alloy, avoid antimony)
Wet sponge
Diagonal cutters
needle nose pliers
Electrical tape
Wire stripper
gloves (not needed but use them if you like having un-burnt fingers)
3M respirator (again, not needed but i treasure my lungs and breathing in lead fumes may not be very healthy)
Parts list (for this application):
2 Oznium 19" white LED strips
2 SPST 12v automotive relays
1 roll of 14awg wire (several colors are recommended)
3 zener diodes (i used 12volt 5A diodes....might be over kill though)
2 SPST switches
2 fuse holders
2 2A fuse (replaces the 1A and 20A fuse in the diagram
1 box of 14-22awg male and female spade connectors (make sure they fit the relay blades)
1 box of 14-22awg U connectors
1 box of wire taps
Here is my wiring diagram, it should be pretty easy to follow. Please note that this was drawn specifically for my application which is why there are certain changes listed in the parts list:
I do not have pictures of the wiring for the lower left relay, since I made that a long time ago. You shouldn't really need the pictures actually, here are pictures of the new harnesses i recently made to give you an idea of what it should look like:
Pin 30 to +12v
Switch harness
Pin 87/ACC +12 to Pin 86
Connectors added to LED strips
Here's where my main switch is mounted (i figured it would be cheaper to replace that cover than the entire lower piece:
Here are some pictures of the Oznium LED strips:
Here's how the lights behave when I unlock/lock the car:
